8 years agofpga startup problem
Good afternoon, members of the forum. I have stratix V. I have such a problem. I write down the firmware in the epcq through the AS. The process is normal. In the firmware, I activate one ...
8 years ago --- Quote Start --- I found that the conf_done pin is connected through a 10k resistor not to Vccpgm (3V), but connected through a 10k resistor to a neighboring i/o pin --- Quote End --- HI, Okay, problem solved?
