8 years agofpga startup problem
Good afternoon, members of the forum. I have stratix V. I have such a problem. I write down the firmware in the epcq through the AS. The process is normal. In the firmware, I activate one ...
8 years agoHi,
1.Have you programmed sof file successful? 2.Is nStatus low form power on state? When the nSTATUS is low, the possibility is either due bit-stream corruption or power issue. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
