12 years agoFPGA reset asynchronous or synchronous?
I normally reset all my d-types using their asynchronous input. I have done this for a long time without any issues. The other day I was chatting to someone else and he said it is best practic...
12 years agoIf you have a asyncronious reset, which also clears asynchrone you might end up with some meta-stability after the reset, and you don't want this. You can prevent this by using a synchrone reset, but this gives troubles if you have a reseet affecting the clock, or timing problems. The solution I use is to trigger the reset asynchrone and then clock the clear through two flip-flops to get it synchronised. In this way you have the best of both worlds.
[edit] attached is a RTL-viewer schematic of the circuit, but than with a dual-input high to trigger the reset. [/edit]
