FPGA Programming Via USB instead of Programming Pod
Hello, I see that Digilent has a JTAG-SMT-NC module that allows the Xilinx tools to program the FPGA over USB with any FPGA programming pod. Does anyone know if there is such a chip that supports the Quartus tools?
https://digilent.com/shop/jtag-smt4-surface-mount-programming-module/
Thank you
you can use any JTAG adapter you want, or build your own, provided you don't use SignalTap or time-limited components -- these two features still require the Altera USB Blaster.
For any other design, convert your file to SVF format, that lists the exact sequence of JTAG signals to initialize the FPGA in a readable format that can be interpreted e.g. by OpenOCD.
Simon
- NurAiman_M_Intel
- SimonRichter
Simon
- joe306
Thank you very much
- NurAiman_M_Intel
Sorry to tell you that we do not have that chip. We do not have USB Blaster chip embedded on board.
Aiman
- NurAiman_M_Intel
Are you looking for Intel USB Blaster?
https://www.digikey.my/catalog/en/partgroup/usb-blaster-and-usb-blaster-ii-download-cables/39122
Aiman
- joe306
Hello and thank you for responding to my post. No, I'm talking about a chip that will allow you to connect to your FPGA's JTAG via USB and the Quartus tools will be able to program the boot code onto the FPGA or the FPGA's boot memory. So you don't need a USB Blaster programming pod. Take a look at Digilents chips:
https://digilent.com/shop/jtag-smt2-surface-mount-programming-module/
All I do is use this module connect it up as the datasheet instructs and the Xilinx tools will be able to interface with it and program your FPGA.
I was wondering if there was such a chip that supports the Intel FPGA's and tools.
Very cool, don't need a USB blaster only a USB cable.
Respectfully,
Joe
