FPGA Programming Via USB instead of Programming Pod
- 5 years ago
you can use any JTAG adapter you want, or build your own, provided you don't use SignalTap or time-limited components -- these two features still require the Altera USB Blaster.
For any other design, convert your file to SVF format, that lists the exact sequence of JTAG signals to initialize the FPGA in a readable format that can be interpreted e.g. by OpenOCD.
Simon
Simon
Thank you very much
