15 years agoFPGA Powering PCB Guidelines??
Could someone provide some PCB design guidelines concerning powering my EP3C16Q240 FPGA? I can only use a 2 layer design, and I need 1.2 V to power the FPGA core and 2.5 V to power all the I/O buffers. Should I use some kind of "voltage bus" for each of the voltage values then connect each pin to those buses and decouple accordingly with capacitors? What if just I connect the voltage pins (of the same value) together, then connect some of them to the corresponding voltage regulator? Would this cause some of those pins to receive reduced voltage and even design failure?
