16 years agoFpga_"PHY" to RJ45 with transformer
Hello guys, I want to connect the Pluto2 fpga board which is trasmitting only to a Pulse RJ45 J006. I will connect the pin_4 to a 100nF Cap on th GND. And i am not sure about what to do ne...
16 years agoFirst, i am not using the circuit i sketched above, i have only a Cap 100nF on the transformer PIN 4 (in the middle of the transformer) with out this the Tx+ and Tx- after the magnetics are equal.
Second, I am using the exact code of the fpga4fun.com which is tested from many users, so its not a fpga problem, its on the transmittion and probably i have done some mistake on my pcb and the ethernet packets can be received from the PC. Thank you for your interest once more you give me your lights :) If you can help me further it will be appreciated. Giannis
