FPGA passive serial configuration -- detect as PCIe device in Linux after configuration
- 1 year ago
Hi Steve,
Thanks for your confirmation, I will transition this support thread to community.
I saw corestar have reply some workaround, perhaps you may refer to that and see if that able to help you or not.
Any time in future, if you having any problem, you may file a new thread.
Someone will be there to support you. If you need my support on PCIe IP, please mention my name "Wincent" so that this will route to my support Q.If your support experience falls below a 9 out of 10, I kindly request the opportunity to rectify it before concluding our interaction. If the issue cannot be resolved, please inform me via this forum page of the cause so that I can learn from it and strive to enhance the quality of future service experiences.
Wincent_Altera
p/s: If any answer from the community or Altera Support is helpful, please feel free to give the best answer or rate 9/10 survey.
in my view it's unwanted to get the FPGA reconfigured unconditionally during PC reboot. This should only happen on power-on reset or explicite request. I can confirm that evaluation boards like Terasic Arria TR10a-HL are keeping FPGA configuration during PC reboot.
This allows to check if the initial PCIe device enumeration works with your design.
You previously mentioned you are not sure if NCONFIG is triggered in your hardware during reboot, but it should be easy to find out, e.g. by loading a test configuration over JTAG.
Does the remove/configure/rescan sequence work for your with other configuarion methods, e.g. JTAG or AS?
Frank
- Steve-Mowbray-ENL1 year ago
Hi Frank
- "Does the remove/configure/rescan sequence work for your with other configuration methods, e.g. JTAG or AS?"
- yes when we do an AS build and load the FPGA flash device with resulting JIC and also change the MSEL pins the FPGA PCIe device is enumerated and we can remove/rescan at will -- we can also change the MSEL pins while still running then do a passive serial write of our passive serial build RBF and remove/reset/rescan the PCIe devices into a working condition -- but what we want is power on in PS mode and do the FPGA configuration that way
you mention the Terasic Arria TR10a-HL -- does that run with PC Linux and if so what is the sequence to rescan the PCI device when the FPGA is configured?
Steve
