FPGA Initialization / Reset
Likely power on RESET derived from the internal power rail monitors. So you get a RESET after power on and configuration whether you assert the RESET pin or not. The RESET pin just allows you to reset the chip any time from an external source after it has powered up and been configured.
- AngelVillanueva3 years ago
Thank you for your response.
In this application, I need to be able to reconfigure the FPGA in case of CRAM error due to SEU failure.
I cannot manage the reset signal with power rail monitors since a SEU failure can happen with the power supplies fully stabilized.
I am evaluating using the CONF_DONE or INIT_DONE signals.
- CONF_DONE: As a status output, the CONF_DONE pin drives low before and during configuration. After all configuration data is received without error and the initialization cycle starts, the CONF_DONE pin is released. As a status input, the CONF_DONE pin goes high after all data is received. Then the device initializes and enters user mode. This pin is not available as a user I/O pin.
- INIT_DONE: This is a dual-purpose pin and can be used as an I/O pin when not enabled as an INIT_DONE pin in the Quartus II software. When this pin is enabled, a transition from low to high on the pin indicates that the device has entered user mode. If the INIT_DONE output pin option is enabled in the Quartus II software, the INIT_DONE pin cannot be used as a user I/O pin after configuration.
However, it is important for me to clarify if it is always necessary a hardware reset signal or there are others ways to guarantee FPGA initialization in a known state.
