10 years ago
FPGA fallback (factory) image in EPCQ256 using local upgrade
I boot my Cyclone V from a EPCQ256. I would like to have a fallback image as well as an application image on the EPCQ256. If I understand correctly I have to configure the EPCQ256 for 3-byte addressing, but Quartus configures it for 4-byte addressing.
Is there any guide for using a fallback image with EPCQ256?
Thanks in advance!
  • Yin1's avatar
    Yin1
    Hi sir,
    Your question is very interesting, any update later? You can contact me by my email: [email protected].
    Thank you very much!
    BR
    Yin
    Could someone please explain what this means:
    "A Programmer Object File for Local Update is a Programmer Object File that consists of a local update enabled Programmer Object File and additional local update enabled SRAM Object Files, and is used to program configuration devices in local update configuration mode. You create a local update enabled Programmer Object File by adding local update enabled SRAM Object Files to a Programmer Object File in the Convert Programming Files dialog box."
    source: http://quartushelp.altera.com/15.1/#reference/glossary/def_pof.htm
    How do I create a "local update enabled SRAM Object Files"?
