10 years agoFPGA fallback (factory) image in EPCQ256 using local upgrade
Hi, I boot my Cyclone V from a EPCQ256. I would like to have a fallback image as well as an application image on the EPCQ256. If I understand correctly I have to configure the EPCQ256 for 3-byt...
10 years agoCould someone please explain what this means:
"A Programmer Object File for Local Update is a Programmer Object File that consists of a local update enabled Programmer Object File and additional local update enabled SRAM Object Files, and is used to program configuration devices in local update configuration mode. You create a local update enabled Programmer Object File by adding local update enabled SRAM Object Files to a Programmer Object File in the Convert Programming Files dialog box." source: http://quartushelp.altera.com/15.1/#reference/glossary/def_pof.htm How do I create a "local update enabled SRAM Object Files"?
