16 years agoFPGA early input output planning
Hello friend , I am working on Cyclon 3 FPGA, EP4C487.I use this FPGA to implement Glue logic.Right now i am not implemeting my software to FPGA, but only designing my PCB. To design schematic ...
16 years ago --- Quote Start --- thank you for above process..I did same as u said but i have problem after below step... When finished, go to assignments > pins Assign pin,How can i assigne pins for add[19...1].I want to use bank 3 and 4 ... there are pin like DIFF_n,DIFF_p,DQ, Other dual purose(this is all symbole name from pin legend)..I dont know , how can i assigen pin to it ? --- Quote End --- Yes you can assign your signals to pins labeled DIFF_n and DIFF_p. These can be used in pairs for differential signals, but when you use single ended signals, like your address and data bus, they can be used individually. Just try. If you make a mistake, Quartus will complain. Good luck, Ton
