16 years agoFPGA early input output planning
Hello friend , I am working on Cyclon 3 FPGA, EP4C487.I use this FPGA to implement Glue logic.Right now i am not implemeting my software to FPGA, but only designing my PCB. To design schematic ...
16 years agoHi Sameerr11,
First of all, the partnummer you mention is unknown. Probably a typo. Making an early pin planning is not to difficult. I suppose you have Quartus II installed. Lets take a schematic as a toplevel. - Open QII. - select file > new > Quartus II project - In the wizard, answer all the questions. - When finished, select file > new > block diagram/schematic file - Select the symbol tool at the left of the schematic (AND symbol) - Unfold till you get pin: bidir, input, output - Put the appropiate pins in the schematic - Change names (address-bus could be A[18..0]) - Save under the same name as project name - Start Analysis & Sythesis - Ignore warnings about "missing source" - When finished, go to assignments > pins - Assign the pins. - Redo Analysis & Sythesis Finished. Just to give you a quick start. I probably forgot some steps. Check the QII handbook for details. Good luck, Ton
