FPGA design that overloads the FPGA and varing it's power consumption
Hi there,
1, I need a design (or a guidance) that consumes a lot of ALMs and it makes the FPGA to consume more power.
We do not have an exact design which is dedicated to consume as much as FPGA ALM resource. I can only suggest some general and simple notes. You can check in Quartus Compilation Report and check how many ALMs are used.
For RTL design and Logic: 1) Use more parallel logics, such as high-width signal calculation, repeating certain logic modules. 2) Use deeper pipeline structure.
For Timing: 1) User higher clock frequency. 2) Set constraints more strictly which would leads to higher resource usage.
2, And in the next level, I would like to control how many ALMs this design requires.
If you would like to know how to reduce the ALM resources used in your design, you can refer to Intel® Quartus® Prime Pro Edition User Guide: Design Optimization and see if it meets your need.(https://www.intel.com/content/www/us/en/docs/programmable/683641/23-2/faq.html)
If you meant that you wants to adjust how many ALMs are used when the FPGA is running, it is actually not applicable. The resource used in your design is fixed after Fitting (placing and routing). If you wants to change the ALM resource used in FPGA, you have to do reconfiguration (Simply reconfiguring a new design, Partial Reconfiguration, or Dynamic Reconfiguration.)
Thanks & Regards,
Xiaoyan
