17 years ago --- Quote Start --- The output pin was a valid pin. I used the same output pin in the NIOS application wihtout any problem. --- Quote End --- It doesn't make sense to say your vhdl doesn't work while nios works(nios is just vhdl platform produced by SOPC). I am sure your testing is wrong, try signaltap instead of pins and make sure your vhdl is not optimised away.
