16 years agofloating license showing no check out
we successfully connect to the license server and checkout out licenses however there is no checkouts are showing up in the logs. [root@finnegan /home/admin]# ps -ef | grep altera flexlm ...
16 years agoHi,
If you are compiling for a device which is only supported in Altera's subscription version you should see a check out in the log when you run the fitter. You might not see a checkout event for synth only, or if you are compiling for a Web edition supported device. The other method of checking status is to run: lmutit lmstat -a -c port@server this will return the current status of the server. I am running a server on solaris 9, and I am seeing all checkouts, however I am creating a log by piping the output of lmgrd to a file >& rather than with the -l option
