16 years agoFlex 6000 clock gating
Hi I've been converting a 10 year old non-synchronous design to make synchronous so that it is more robust. Due to the available clocks on the board, it is necessary to use a gated clock. The o...
16 years agoQuite curious indeed.
I'd go and look at the postfitting netlist for -1 and -2 speed grades. I'd also go and take a look at the waveforms for the pins of the LEs involved. From there, you might be able to work arround the issue by placing a delay LCELL somewhere in the design.
