16 years agofixed point multiplication
Hi. I have a signed multiplication to perform in the following format: a(32.0) * b(2.30) Limitation of b(2.30):range from -1 to 1 FYI, i will only get the correct result whenever my out...
16 years agoDid you verify, that your truncated result is correct for a = -2**31 and b = -1 (the most negative numbers)? If not, saturation logic is required.
