16 years agofixed point multiplication
Hi. I have a signed multiplication to perform in the following format: a(32.0) * b(2.30) Limitation of b(2.30):range from -1 to 1 FYI, i will only get the correct result whenever my out...
16 years agocan you give an example and how u declare the a, b and result? thanks
Besides, my result is very weird. e.g. 3 * 1 = 4. code and vwf is attached. Pls comment on it. However, when i perform 4.0 * 2.2, I get the correct result using the same code. May i know why?
