15 years ago
Fitting 3C16 / 3C25 / 3C40 on same footprint
I am trying to save some time / money by re-using one of my PCB's that was laid out for a 3C40. Can I get away with fitting a 3C16 on the same 240pin PQFP footprint?
I need far less logic in this version so can use a smaller device, but would like to avoid re-laying the PCB.
Fitting a 3C16 on the PCB laid out for the 3C40 connects some IO pins to 1.2V. The IO voltage is 3.3V.
Can I get away with doing this?
Ian.
    At first glance the pin out has minor differences. The larger device has more ground and VCCINT pins which are IO pins on the smaller devices.
    I will post results when I have hardware available.
    Please tell us if:
    1) the pinout is the same
    2) the migration was successful
    It will help me and all the others, who will face the same problem in the future.
    Thanks Socrates,
    My original design was in a 3C40 but the new cut down version will fit in a 3C16. I have 3C16 and 3C25 listed as migration devices in Quartus 9.1sp2.
    Just found some documentation on the subject, think I should be ok.
    You have to check ALL the pins. However, I see that Quartus allows migration between 3C25 and 3C40, so I believe, that 3C16 will not fit.
