14 years agoFirst in Last out buffer consuming too much resources
Hi all, I'm trying to implement a first in last out buffer, that has the soul purpose of flipping image data horizontally. The image comes in as a stream of pixels in the order (1,1) , (2...
14 years agoThanks tricky,
I have written a testbench and fully tested the block, I just left it out of the post so the post was not too long but I've included it below now. With regards to the variables, there's no reason I need them in this design, my previous design was simplified by using variables instead of signals and I just didn't get around to changing them back to signals when I redesigned the block but I will change them back to signals. What is the reason I should stick to variables for now? I will read the design guidelines for altera RAM, but my main question is, is the fact that the arrays are not being inferred to RAM the reason why the block is using so many logic elements? Mat. Testbenchlibrary ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity Flip_test is
generic (
LABEL_WIDTH : integer := 8;
COORD_WIDTH : integer := 10;
BUFFER_SIZE : integer := 5--765 -- Screen width
end Flip_test;
architecture bench of Flip_test is
component FlipBuffer
port (
-- Clock Signal
CLK : in std_logic;
-- Input Signals
CL_IN : in unsigned(LABEL_WIDTH-1 downto 0);
X_IN : in unsigned(COORD_WIDTH-1 downto 0);
Y_IN : in unsigned(COORD_WIDTH-1 downto 0);
DVAL_IN : in std_logic := '0';
FVAL_IN : in std_logic := '0';
-- Output Signals
CL_OUT : out unsigned(LABEL_WIDTH-1 downto 0) := to_unsigned(0,LABEL_WIDTH);
X_OUT : out unsigned(COORD_WIDTH-1 downto 0) := to_unsigned(0,COORD_WIDTH);
Y_OUT : out unsigned(COORD_WIDTH-1 downto 0) := to_unsigned(0,COORD_WIDTH);
DVAL_OUT : out std_logic := '0';
FVAL_OUT : out std_logic := '0'
end component;
signal CLK, DVAL_IN, FVAL_IN, DVAL_OUT, FVAL_OUT : std_logic;
signal CL_IN, CL_OUT : unsigned(LABEL_WIDTH-1 downto 0);
signal X_IN, Y_IN, X_OUT, Y_OUT : unsigned(COORD_WIDTH-1 downto 0);
BEGIN
clk_process :process
begin
CLK <= '0';
wait for 100 PS;
CLK <= '1';
wait for 100 PS;
end process;
stim_process :process
variable odd : std_logic := '1';
variable run : std_logic := '1';
variable count : unsigned(COORD_WIDTH-1 downto 0) := to_unsigned(0,COORD_WIDTH);
begin
DVAL_IN <= '0';
FVAL_IN <= '0';
CL_IN <= to_unsigned(0, LABEL_WIDTH);
X_IN <= to_unsigned(0, COORD_WIDTH);
Y_IN <= to_unsigned(0, COORD_WIDTH);
wait for 150 ps;
DVAL_IN <= '0';
FVAL_IN <= '0';
CL_IN <= to_unsigned(4, LABEL_WIDTH);
X_IN <= to_unsigned(2, COORD_WIDTH);
Y_IN <= to_unsigned(3, COORD_WIDTH);
wait for 200 ps;
while (run = '1') loop
if (count = to_unsigned(10,COORD_WIDTH)) then
run := '0';
end if;
if (odd = '1') then
odd := '0';
DVAL_IN <= '1';
FVAL_IN <= '1';
count := count + 1;
CL_IN <= to_unsigned(8, LABEL_WIDTH);
X_IN <= count;
Y_IN <= count;
wait for 200 ps;
else
odd := '1';
DVAL_IN <= '0';
FVAL_IN <= '1';
--count := count + 1;
X_IN <= to_unsigned(333, COORD_WIDTH);
Y_IN <= to_unsigned(333, COORD_WIDTH);
wait for 200 ps;
end if;
end loop;
DVAL_IN <= '0';
FVAL_IN <= '0';
X_IN <= to_unsigned(222, COORD_WIDTH);
Y_IN <= to_unsigned(222, COORD_WIDTH);
run := '1';
wait for 200 ps;
if (odd = '1') then
odd := '0';
DVAL_IN <= '1';
FVAL_IN <= '1';
count := count + 1;
X_IN <= count;
Y_IN <= count;
wait for 200 ps;
else
odd := '1';
DVAL_IN <= '0';
FVAL_IN <= '1';
wait for 200 ps;
end if;
end loop;
--wait;
end process;
M: FlipBuffer port map (CLK, CL_IN, X_IN, Y_IN, DVAL_IN, FVAL_IN, CL_OUT, X_OUT, Y_OUT, DVAL_OUT, FVAL_OUT);
end bench;
