14 years agoFinding name in block diagram
hi~ I have a problem finding name in blcok diagram.
i made a fulladder with vhdl language. but i want to make a fulladder with block diagram.. but i cant find where it is!! Do you know the way to find logic names?3 Replies
in the VHDL file, you need to create the block diagram.
Go to File -> Create/Update -> Create Symbol files for current file That should add the symbol to your current project. - Altera_Forum
--- Quote Start --- in the VHDL file, you need to create the block diagram. Go to File -> Create/Update -> Create Symbol files for current file That should add the symbol to your current project. --- Quote End --- i can't understand what you say.. can you expalin more in detail? in my thought.. after i did all you ordered,, nothing happened.. - Altera_Forum
once you've created the symbol file, you then double click in your block diagram file and find the entity you want to place.
