tiger97194044's avatar
tiger97194044
1 month ago
FFVH-ICS-0923-00(1SM21BHU2F53E2VGNE)failed at ESS-HOT test
Hi, There was one piece FFVH-ICS-0923-00(1SM21BHU2F53E2VGNE)failed at ESS-Hot test(at 45 Celsius) and the failure item is HIGH ATSE2CPU Results. I have contacted with the supplier Arrow, but they insisted that we need to contact with Altera directly. We want to return this unit, pls. help to check and confirm back with RMA#.
The date code of this unit is 2431, and I have attached the shortcut of the two test results of swapping to two FG for verification for your reference.
  • Hi Farabi,
    Is there any update for this case? I had sent you the DPR to you days before.
    pls. help to expedite.
    thanks.
    Tiger.
    • Farabi's avatar
      Farabi
      Status : Processing the FA request.
  • Hi Farabi,
    pls. help to provide the DPR form to me so that I can fill in it and lay it to you for the next step.
    thanks.
    Tiger
  • Hi Farabi,
    could you pls. share the DPR form so that I can fill in it and send back to you for the FA application.
    thanks.
    Tiger
    • Farabi's avatar
      Farabi
      Hi Tiger,
      Did you get the DPR form?
      regards,
      Farabi
  • Hi Farabi,
    I don't see any attachment in your page, could you pls. double check?
    Tiger
  • Farabi's avatar
    Farabi
    Hello, to proceed FA, please fill in this DPR form in attachment.
    regards,
    Farabi
