15 years ago
fast adc connect to cyclone ii
I have a 250M sample rate ADC ( AD9481 , two 8 bit output channels) connect to cyclone II EP2C8Q208C8 , two of their pins ( DCO+ and DCO-, their clock is 60M) are differential output are connect to differential inputs of EP2C8Q208C8 . When dco+ is raising edge channel 1 data is valid while dco- is raising edge channel 2 data is valid. Under the code below :
module mux3(dco+,dco-,data1,data2,data3);
input dco+,dco-;
input [7:0] data1;
input [7:0] data2;
output [7:0] data3;
reg [7:0] data3;
reg sela;
reg selb;
reg [7:0] data_a;
reg [7:0] data_b;
initial begin
sela = 1'b0;
selb = 1'b0;
end
always @ (posedge dco+) begin
sela <= ~ selb; // warning, must meet setup/hold
data_a <= data1;
end
always @ (posedge dco-) begin
selb <= sela; // warning, must meet setup/hold
data_b <= data2;
end
always @ (sela, selb, data_a, data_b) begin
if (sela^selb) begin
data3 = data_a; // warning, combinatorial output.
end else begin
data3 = data_b; // warning, combinatorial output.
end
end
endmodule
The question I ask is can the code above function properly as two channels are multiplex and only one channel is selected as output ????
    hi everybody
    I wanna recive with the Cyclone II the dates from the outputs pins of the ADC (9481), how can I do it?
    I have DDIO out block with LVDS positive pin and negative differential pins (for out clock as input) assignment without success , it said the following error :
    Error: Node "outclock" is used as the input clock of DDIO output registers but does not use global clock ......
    Can you help me ??
    You would normally use DDIO registers to combine port A and B to a single 250 MBPS signal. Read about the Quartus altddio_in block. But depending on how you want to process the data in your FPGA, you possibly may want to leave both streams apart.
