15 years agofast adc connect to cyclone ii
I have a 250M sample rate ADC ( AD9481 , two 8 bit output channels) connect to cyclone II EP2C8Q208C8 , two of their pins ( DCO+ and DCO-, their clock is 60M) are differential output are connect to d...
15 years agoI have DDIO out block with LVDS positive pin and negative differential pins (for out clock as input) assignment without success , it said the following error :
Error: Node "outclock" is used as the input clock of DDIO output registers but does not use global clock ...... Can you help me ??
