F-tile Reference and System PLL Clocks: mising port documentation
- 1 year ago
Q1- Can out_coreclk_i used to drive IOPLL?
<ANS> No. out_coreclk_i is not routed through dedicated clock paths required by IOPLL.
Q2- Is there workaround to indirectly use out_coreclk_i for IOPLL reference?
<ANS> a. Use Clock Control IP.
b. Use dedicated clk routing.
Q3- Fitter error and HSSI_PLDADAPT_RX
<ANS> error is due to placement constraints and routing limitation between HSSI components and core logic. In your case, HSSI_PLDADAPT_RX is constrained to a specific region, but the core logic needs to connect to is placed elsewhere, and there is no valid routing path. Please review your location constraints. Avoid using out_coreclk_i for clocking components that require dedicated routing.
Q4- Can altera_fifo be driven by out_coreclk_i ?
<ANS> yes, they are not dependent on IOPLL reference. FIFO IP is designed to work with fabric routing.
regards,
Farabi
Hi Farabi,
Thank you for your assistance, these answers are helpful. I will close this thread now.
Cheers,
Sam
