15 years agoExternal Memory Interface Toolkit
Hello, I'm trying to get the EMIF toolkit up and running and I'm having some difficulty with the CSR. Hopefully someone has run into this before and can help! I can get to the point in sy...
14 years agoBruce,
I'm using a Stratix IV GX so I'm not sure it's useful to you. However it is DDR2 with UniPhy and it has been successfully tested in hardware using the Memory Test example in SBT for Eclipse and a few parts of the EMIF toolkit. I've been working through calibration in another thread if you're interested. The only piece I'm missing now is the CSR so I can use the full functionality of the EMIF toolkit. http://www.alteraforum.com/forum/showthread.php?t=32337 Hope this helps, Scott
