8 years agoExport synthesized top-module and import in another project
I am working on a project where different engineers will be developing different modules of a large design completely separately. The design must be entirely bottom-up because the module developers may never know anything about the rest of the design. So, I need the ability to create a project, synthesize it, and export the netlist (along with a stub file). Then, in another project/design I need to import that netlist as a submodule.
I was able to do this easily in Quartus Standard (versions 12-17) by exporting a QXP netlist and importing that netlist in another project. In Quartus Pro 17.0, QXP netlists are no longer supported. I attempted to do the same thing using QDP files, but had no luck. I tried exporting the design as a "partition" but it will not let me export the top-module as a partition (only sub-modules). Export/import "design" does not help here either because when "importing", it seems to assume the design (QDB\) file being imported represents the entire design. So, how can I export a synthesized design from the top-module and import the result (netlist or qdb...) in another project? As a reminder, my use-case involves lower-level designs that will never have any knowledge of the higher-level designs. So, it is not possible to create a full design and designate sub-modules as partitions. Note: while I use the GUI to figure things out, ultimately my projects will be entirely command line, so any Tcl or command-line commands are very helpful (e.g. quartus_syn/quartus_cdb commands/options).
