8 years agoExport synthesized top-module and import in another project
I am working on a project where different engineers will be developing different modules of a large design completely separately. The design must be entirely bottom-up because the module developers m...
8 years agoThat's not how design reuse works. You don't reuse the top module from multiple projects because there can only be one top that connects to the I/O. Are you saying that there is no overlap of top-level I/O use between the three projects? If that's the case, the easiest thing would be to create a new top-level design entity (.v or .vhd) that merges the I/O pin use of the three designs and instantiates the three designs then use .qdb files for the submodules for each design. Basically create a top-level wrapper file.
