8 years agoExport synthesized top-module and import in another project
I am working on a project where different engineers will be developing different modules of a large design completely separately. The design must be entirely bottom-up because the module developers m...
8 years ago --- Quote Start --- I just tried it out. You need to be using 17.1 and you have to be targeting Arria 10. If you do that, then you can export a .qdb of the whole project without creating a wrapper or just exporting the root_partition. --- Quote End --- If you export the whole design, how can you import that in another project? It appears that importing a design is the equivalent of 'replacing' your current design with the contents of that QDB file. Therefore when 'importing' a design, Quartus Pro expects the design to have the same 'revision' as the current project.
