8 years agoExport synthesized top-module and import in another project
I am working on a project where different engineers will be developing different modules of a large design completely separately. The design must be entirely bottom-up because the module developers m...
8 years ago --- Quote Start --- I just tried it out. You need to be using 17.1 and you have to be targeting Arria 10. If you do that, then you can export a .qdb of the whole project without creating a wrapper or just exporting the root_partition. --- Quote End --- I will go ahead and try this on 17.1. Unfortunately, my production design may need to be 17.0 due to other requirements. I will keep you updated as I experiment. Thank you for all of your help.
