17 years agoExceed recommended operating condition
Hi, I'm sorry for making a very low level question. If input signal level of FPGA exceeds the recommended operating conditions, i.e. higher than 3.6V, what will happen? Increase jitter? ...
17 years ago --- Quote Start --- but is it true for case not violating absolute rating and exceeding recommended operating conditions? --- Quote End --- This question sounds rather theoretical to me, at least in case of a 3.3V I/O standard. Typically you get some additional overshoot, and should rather worry about violating the maximum ratings. In case of the the single ended I/O standards, I wouldn't expect particular problems, if you manage to stay precisely in the maximum rating intervall. I guess, there are much more designs out there, that don't actually keep maximum ratings and still work. As a simple mean of reassurence, many designers simple don't measure some critical signals... Recommended operating conditions can be expected as an issue with differential I/O standards, e.g. keeping the common mode range or the differential voltage level. I have seen e.g. LVDS receivers still working without a termination resistor. But it's very unlikely that the timing specifications are still maintained in this case.
