Dear Dave,
Thank you very much, your explanation and instruction help me understand my target system really better. Still, I have some doubts as follow.
--- Quote Start ---
1) A PCIe 10Gbps NIC (network interface card) with SFP+ connectors. Eg., Newegg has them
http://www.newegg.com/product/product.aspx?item=n82e16833106057 http://www.newegg.com/product/product.aspx?item=n82e16833120384 --- Quote End ---
My boss said that we have NIC with SFP+ connector for our server. So I assume that we have already had this by now.
--- Quote Start ---
2) A couple of SFP+ to SMA breakout cables or boards, eg.,
http://hitechglobal.com/boards/modules/sma_to_sfp+.htm --- Quote End ---
And this is what we will need to have to realize our target application, am I right?
--- Quote Start ---
3) Plug the NIC into your test PC, plug the SFP+ cable into the NIC and the adapter board, and then wire the SMAs onto your SI kit.
--- Quote End ---
This is how I set up a connection from a test PC to my SIV GT SI board for transferring 10Gbps, is that right?
My next wonder is how I can transfer data from the test PC to board in terms of implementation? if there is an existing tool for this or I need to create my own software/design?
--- Quote Start ---
However, in hindsight, you should have just purchased a GT board with SFP+ connectors on it already, eg.,
http://www.hitechglobal.com/boards/stratix4gx.htm --- Quote End ---
I am not sure if I understood your point here. But I still do not have SFP+ connector. I have only the XCVR SI Dev kit, SIV GT, eg.,
http://www.altera.com/products/devkits/altera/kit-stratix-iv-gt-si.html --- Quote Start ---
Note that if you are just connecting your two SI kits together using 10Gbps, you can just use SMA cables there.
--- Quote End ---
This is clear for me. This is what I am doing for testing the XCVR Toolkit examples.
