14 years agoExample designs for communicating two Altera boards
I am looking for example designs or tutorials showing how to communicate two Altera boards using simple protocols. The purpose is to see how the two devices interact by transmitting data back and for...
14 years ago --- Quote Start --- Look at the $600 Intel NIC. Check if its supported under Windows 7 and Linux RedHat 6 (or Centos 6). Even if you're not going to use Linux, its a good indicator that the NIC works well and is documented (since the Linux guys had enough info to write a driver). --- Quote End --- It says "Support for most Network Operating Systems". So I think that no way to have a driver in Windows 7 or XP. You have any ideas?
