14 years agoExample designs for communicating two Altera boards
I am looking for example designs or tutorials showing how to communicate two Altera boards using simple protocols. The purpose is to see how the two devices interact by transmitting data back and for...
14 years ago --- Quote Start --- It looks like your script output stops right around the time Java is started. Perhaps Java on Windows Server 2008 is broken. --- Quote End --- I have just tried the generation with Quartus II 11.0 sp1 installed in Window 7 OS. And it was fine. So, I will check the time java on the server. In case, it does not help, we will need to reinstall an supported OS. Now I see why my boss want me to use the Windows Server 2008. The server has a NIC with SFP+ connectors and he has been told that the NIC just works with Win Server 2008. I need to investigate this soon. But, if this is true, how should we do? --- Quote Start --- You will not get any response to requests for support until you are using a supported OS. --- Quote End --- A reason strong enough for us to decide changing the OS. Thank you very much. PLMT
