EVENT 122945 ALC3-1AB227640008_REP, 1 PC / EZ1603B1328
Please support with this case.
I have attached the material problem report.
Component details:
Material PN |
ALC3-1AB227640008_REP |
Material Description |
OBELIX 100 |
Material SN or Lot Nr |
CDFAG1549A |
Date Code or Part Mark |
N/A |
Supplier Name |
ALTERA |
Supplier PN/MPN |
EP4S100G5H40I1N |
- Problem description: U9003 (PN: 1AB227640008) defective
- Detected by: Customer field failure, failure confirmed by factory tests
- Quantity Affected: 1 PCS
- Failure Message: “8mff on asterix Client Chennel =0 and 8mff on astrix Client channel = 1”
- Flex analysis:
This units failed in field at customer with “ 8mff on asterix Client Chennel =0 and 8mff on astrix Client channel = 1” error. Flex factory test confirmed this error: Doing the loop back CLNL at internal of obelix the alarms are not detected, instead doing the loop back CLML at internal the obelix the alarms are detected.
Replacing the component solved the problem and card passed factory tests.
1 Reply
- Zawani_M_Intel
Dear Ionela,
Thank you for using Intel FPGA Community Forum.
Your case will be supported through private email. Please do let me know if you having problem to access the email.
Thanks!
Wani
