Ethernet RGMII Cyclone V
I'm trying to implement an ethernet application in RGMII mode with a NIOS processor in a Cyclone V 5CSEMA5F31 FPGA and Quartus Prime standard Edition 18.1.
I followed a tutorial for Triple-Speed_Ethernet IP and I instantiated the following components in QSYS:
- NIOS II Processor
- CLOCK NIOS
- On-Chip Memory (NIOS - TSE)
- Triple-Speed Ethernet Intel FPGA IP (RGMII)
- Scatter-Gather DMA Controller RX
- Scatter-Gather DMA Controller TX
- On-Chip Memory Intel FPGA IP (descriptor memory for sgdma)
I created the Soc_system with the QSYS and I connected input and output to the respective ports.
This error occurred during the Analysis&Synthesis :
Error (15871): Input port DATAIN of DDIO_IN primitive "soc_system:comp_SoC_System|soc_system_eth_tse_0:eth_tse_0|altera_eth_tse_mac:i_tse_mac|altera_tse_rgmii_module:U_RGMII|altera_tse_rgmii_in1:the_rgmii_in1|altddio_in:altddio_in_component|ddio_in_gsd:auto_generated|ddio_ina[0]" must come from an I/O IBUF or DELAY_CHAIN primitive
I tried to use an ALTIOBUF component for the input bus RGMII_RX(3 downto 0) but it does not work.
Can you help me?
Bryan
The solution is to use the Modular Scatter Gather DMA instead of the SGDMA that is obsolete.
- BIdro
- EricMunYew_C_Intel
You can find it in c:\intelFPGA\20.1\ip\altera\altera_gmii_to_rgmii_adapter.
- BIdro
Hi Eric,
thanks for the reply.
Can you give me an example project or tutorial on this GMII/MII to RGMII adapter?
Bryan Idrobo
The FPGA supports GMII/MII interface. For RGMII, you will need to add adaptor between GMII/MII to RGMII in FPGA fabric.
Are your DATAIN directly connected to input pins?
Alternatively, you may refer to below from Rocketboards.
https://rocketboards.org/foswiki/Projects/CycloneVRGMIIExampleDesign
- BIdro
Yes, the signal input "eth_tse_0_mac_rgmii_connection_rgmii_in" of the HPS is connected directly to the input ports of the top_level.
I saw the project from Rocketboards but the 2 ethernet peripherals are connected to the HPS.
Instead I need 1 ethernet peripheral to be controlled by NIOS processor in RGMII configuration.
Bryan
