BIdro
4 years agoEthernet RGMII Cyclone V
I'm trying to implement an ethernet application in RGMII mode with a NIOS processor in a Cyclone V 5CSEMA5F31 FPGA and Quartus Prime standard Edition 18.1.
I followed a tutorial for Triple-Sp...
- 4 years ago
The solution is to use the Modular Scatter Gather DMA instead of the SGDMA that is obsolete.
EricMunYew_C_Intel
4 years agoAre your DATAIN directly connected to input pins?
Alternatively, you may refer to below from Rocketboards.
https://rocketboards.org/foswiki/Projects/CycloneVRGMIIExampleDesign
BIdro
4 years agoHi,
Yes, the signal input "eth_tse_0_mac_rgmii_connection_rgmii_in" of the HPS is connected directly to the input ports of the top_level.
I saw the project from Rocketboards but the 2 ethernet peripherals are connected to the HPS.
Instead I need 1 ethernet peripheral to be controlled by NIOS processor in RGMII configuration.
Bryan
