17 years ago
errors in quartus when simulation
I have some code about LEDs cycle. I wrote two process, one is a time divider, the other is LED turn on according with divider. the project was complied, but quartus has some errors when staring simulation.
the error message is Error: Zero-time oscillation in node "|led_glimpse|lpm_mux:Mux4|mux_hfc:auto_generated|_~7" at time 5243903.5 ns. Check the design or vector source file for combinational loop.
I don't know where is wrong in the code to bring this error? Thanks!
the code is displayed as below:
process(Reset,clk)
begin
if Reset='0' then
counter<=(others=>'0');
elsif clk'event and clk='1' then
counter<=counter+1;
end if;
end process;
process(Reset,counter(10),datan)
begin
if Reset='0' then
ledn<=(others=>'0');
datan<=(others=>'0');
elsif counter(10)='1' then
datan<=datan+1;
case datan is
when "000" => ledn<="10000000";
when "001" => ledn<="00000001";
when "010" => ledn<="00000010";
when "011" => ledn<="00000100";
when "100" => ledn<="00001000";
when "101" => ledn<="00010000";
when "110" => ledn<="00100000";
when "111" => ledn<="01000000";
end case;
end if;
end process;
    Hi, Thank you very much!
    why does these statement place to the first process?
    Could you tell me the reason?
    your statement:
    datan <= datan + 1 is combinatorial feedback and leads to oscilation.
    insert that in first process
    kaz
