17 years ago
errors in quartus when simulation
I have some code about LEDs cycle. I wrote two process, one is a time divider, the other is LED turn on according with divider. the project was complied, but quartus has some errors when staring simulation.
the error message is Error: Zero-time oscillation in node "|led_glimpse|lpm_mux:Mux4|mux_hfc:auto_generated|_~7" at time 5243903.5 ns. Check the design or vector source file for combinational loop.
I don't know where is wrong in the code to bring this error? Thanks!
the code is displayed as below:
process(Reset,clk)
begin
if Reset='0' then
counter<=(others=>'0');
elsif clk'event and clk='1' then
counter<=counter+1;
end if;
end process;
process(Reset,counter(10),datan)
begin
if Reset='0' then
ledn<=(others=>'0');
datan<=(others=>'0');
elsif counter(10)='1' then
datan<=datan+1;
case datan is
when "000" => ledn<="10000000";
when "001" => ledn<="00000001";
when "010" => ledn<="00000010";
when "011" => ledn<="00000100";
when "100" => ledn<="00001000";
when "101" => ledn<="00010000";
when "110" => ledn<="00100000";
when "111" => ledn<="01000000";
end case;
end if;
end process;
    you can, but you're liable to have timing failures and have race conditions all over and all sorts of problems.
    What you need to do in your first process is wrap it up as a D-type flip flop process - just put
    if rising_edge(clk) then
    (or you can use:
    if clk'event and clk = '1' then
    at the top, then you wont have a problem. You can remove all signals other than the clock from the sensitivity list. What you have done by putting "if clk = '1' then" at the top is use the clock as a logic signal, not a clock, which is bad, and wont solve any problems.
    --- Quote Start ---
    (or you can use:
    --- Quote End ---
    tnx a lot.
