17 years agoerrors in quartus when simulation
I have some code about LEDs cycle. I wrote two process, one is a time divider, the other is LED turn on according with divider. the project was complied, but quartus has some errors when staring simu...
16 years agoHi I have a similar problem, but i don't put my signal in process sensitive list, so i think it shouldn't make a combinational loop but again i have the same error for oscillating!!!
an interesting point is that the error may disappear in some testcases!!! usually when test case doesn't go in if( inc = '1')!!! i will be glad if any one can help me!!! process( reset, shift, add, inc, swap, comp, datain) begin if (reset = '1') then accumulator <= "0000000000000000"; else if (shift = '1') then accumulator <= '0' & accumulator(15 downto 1); else if (add = '1') then accumulator <= accumulator + datain; else if (inc = '1' ) then accumulator <= accumulator + 1; else if( swap = '1') then accumulator <= accumulator ( 6 downto 0) & accumulator( 15 downto 7); else accumulator <= accumulator; end if; end if; end if; end if; end if; end process;
