17 years agoerrors in quartus when simulation
I have some code about LEDs cycle. I wrote two process, one is a time divider, the other is LED turn on according with divider. the project was complied, but quartus has some errors when staring simu...
17 years ago --- Quote Start --- Hi, Thank you very much! why does these statement place to the first process? Could you tell me the reason? --- Quote End --- When you put the statement in the first process, the update is controlled by the clock and you got registers instead of combinatorial logic for your data_an.
