14 years agoError:Connected system timestamp not found on target at expected base address.
I'm fairly new to FPGA programming, please bear with me. I tried to use Nios II and Quartus II 10.1 on Windows 7(64 bit) to programme a Altera DE2-70 board. I basically followed these procedures: 1) Generate the SOPC which includes the Jtag Uart 2) add all files into the quartus II project and compile 3) Programme the board 4) Create a project including the application and bsp 5) Build the project 6) Run the project as Nios II hardware Then it gives me the error:connected system id hash not found on target at expected base address I tried to follow the posts from the forum and ignored the mismatch in Systemid and System timestamp. Then it gives me: downloading elf process failed. If I click System ID Properties I get: Expected system ID base address: 0x0 (as in SOPC) Expected system ID:0x0 connected system id: not found Expected system timestamp:1343399230 (as in SOPC) connected system timestamp: not found May I know what are the possible issues? Any suggestions would be much appreciated .12 Replies
I download the same program into another FPGA board , it runs OK. Is it possible the fpga is broken?
--- Quote Start --- In your SOPC the cpu reset_n input is not connected. I've attached a screenshot of a SOPC. May be this helps you. --- Quote End --- I download the same program into another FPGA board , it runs OK. So I think the program is right.Is it possible the fpga is broken or other reason?
