Error(261009):Signal tap checksum mismatch
- 4 years ago
The easiest solution is to simply recompile with the current .stp file. Trying to figure out what was changed in the .stp to make it mismatch with the programming files is not easy.
Once you have a matching .sof, you can add it to the SOF Manager in the .stp file (it's in the JTAG configuration section of the window). That way the tool will always let you know if the current .stp file settings are compatible with the programming file.
Hi
Since this thread been resolve, I shall set this thread to close pending. If you still need further assistance, you are welcome reopen this thread within 20days or open a new thread, some one will be right with you.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
