anrfpga
4 years agoError(261009):Signal tap checksum mismatch
Hi All,
I am trying to use the signal tap analyzer while booting the device from the SD card. The HPS is up and running and I am able to run the applications but the signal tap which was working f...
- 4 years ago
The easiest solution is to simply recompile with the current .stp file. Trying to figure out what was changed in the .stp to make it mismatch with the programming files is not easy.
Once you have a matching .sof, you can add it to the SOF Manager in the .stp file (it's in the JTAG configuration section of the window). That way the tool will always let you know if the current .stp file settings are compatible with the programming file.
anrfpga
4 years agoThanks for your response. It helped me resolve my problem. The .sof file that I have to add in the .sof manager window was not up to date. The tool automatically picked an old .sof file that I manually generated from the current directory.
