16 years agoERROR with programer
Hello everyone, i have trouble with programing of my EP3C16Q240, i have my own board (schematic is in attached PDF). If i use USB blaster, quartus 9.0 says this:
Info: Started Programmer operation at Fri Dec 11 12:59:16 2009 Info: Configuring device index 1 Info: Device 1 contains JTAG ID code 0x020F20DD Error: CONF_DONE pin failed to go high in device 1 Error: Operation failed Info: Ended Programmer operation at Fri Dec 11 12:59:17 2009 but programing never start. If i use ByteBlasterII, everything is ok, i can programing my board. ConfDone goes up at the end. But i need USB blaster, because i wanna use Nios II. Please, what is wrong, do you have any idea? Thank you very much for your advice. Vaclav11 Replies
It's not necessary related to the reported problem, but the MSEL wiring is incorrect. MSEL should be hard wired to GND/VCCA.
