16 years agoERROR with programer
Hello everyone, i have trouble with programing of my EP3C16Q240, i have my own board (schematic is in attached PDF). If i use USB blaster, quartus 9.0 says this: Info: Started Programmer operat...
16 years agoi have usb blaster with the yellow cable, but terasic programmer has standard ide cable, but that is very strange. But i have on board only fpga and the interface to programming. Others IO are only on the pins (for whatever what i will be need). I think that is very simply, and routes from JTAG connector to FPGA are really short (about 5cm). But if the yelllow cable is the main reason, its very strange. BTW i used on jtag signals schotky diodes to procestion also.
vaclav
