16 years agoERROR with programer
Hello everyone, i have trouble with programing of my EP3C16Q240, i have my own board (schematic is in attached PDF). If i use USB blaster, quartus 9.0 says this: Info: Started Programmer operat...
16 years agoI don't expect, that the 10k resistors at MSEL are causing problems, the FPGA has internal pull-down resistors in parallel. As most likely reason, USB Blaster doen't work due to signal integrity problems with the JTAG interface.
