16 years agoERROR with programer
Hello everyone, i have trouble with programing of my EP3C16Q240, i have my own board (schematic is in attached PDF). If i use USB blaster, quartus 9.0 says this: Info: Started Programmer operat...
16 years agoYour schematic shows 3 resistors each 10K between MSEL? and GND.
This is not hard wired. you better use 0 Ohm jumpers instead of these resistors Another thing .... Pin 3 and 7 of your serial M25P40 configuration device are left floating, i would connect them to safe power levels instead of letting them float. and ... generating the 40MHz, does this work reliable ?
