16 years agoerror with pin assignment
Hi, i am trying to do a pin assignment but by compile i get this Error Message: "Error: Can't place multiple pins assigned to pin location Pin_AD25 ( IOC_X95_Y2_N1) Info: Pin iSW[7] is ass...
16 years ago --- Quote Start --- Go to the Assignments menu > Device Click on the "Device and Pin Options" button Go to the "Dual-Purpose Pins" tab Double click on nCEO Select "Use as regular I/O" By default nCEO is used as a programming pin (to chain several FPGAs during configuration). You need to tell Quartus that you want to use this pin as an I/O instead. --- Quote End --- thank you for your answer
